I know this has been covered here before, and on other websites. Ive done alot of searching, but cant quite come up with the answers i need.
Ok i just got my truck maybe a month ago. It has only been drove to my house, then sat here while i was fixing the front end that had been wrecked. I drove it down the road a few miles once, and have moved it around the yard a couple times. But thats it, and i havent used the heater or AC. But my passenger floor is getting wet. Im not 100% sure if it was just wet before i got it, and now its drying up, or if it actually got wet after i got the truck. But i tore open the cowl below widow wiper, no debri or anything at all down in there. I located the evaporator drain tube, looks clean. Ran a 12" drain zip-it into the drain tube, it went all the way in, and got absolutely nothing at all out of the drain tube. So makes me think it cant be clogged. Inside the vehicle, under the evaporator, right where the drain tube is built on, but under the carpet, there is some very tacky sticky stuff. I thought either carpet glue, or where antifreeze had leaked. And yesterday when i went out the carpet was wet but more like condensation. And i have a bass stereo in the truck with a capacitor behind the passenger seat. The capacitor was slam covered in condensation. Nothing else at all, just the capacitor, and the floor in front of the seat. But i dont think the drain tube is plugged. I know there isnt water leaking in environmentally. It hasnt rained at all in a week or so. No evidence inside or outside the truck of anything broke, not in place, etc. Only thing i can find is that sticky residue under the very top part of the carpet, and on the bottom of the evaporator. I thought maybe heater core cracked. No coolant level drops, it is completely full. I fired the truck up today and ran it about 15 minutes using both AC and heat. Absolutely no leaking anywhere, and no dripping from the drain tube either. Any thoughts? I very much appreciate the help, i need to get it figured out before the floor starts to rot out. Thanks!!
