Hey everyone so I’ve replaced the thermostat (after market part) tested it, replaced the water pump (after market) no leaks, fan works, radiator doesn’t leak, replaced the coolant temperature sensor (after market) would it be the wiring connecting to my gauge cluster? I took the temperature sensor off and it still shows hot and from letting it sit for a few hours, it goes straight to hit within 10 minutes, talked to some guys at the part store, no typical signs of a cracked head or head gasket, but used an exhaust fume detector on the radiator and it shows I have a fume leak? would a crack head or head gasket cause my truck to show hot?
