1 - 11 of 11 Posts
Hello,
I've got a 98 Frontier that I've had for half a year or so. Last week I noticed a little water under the passenger seat. I pulled up the carpet on the passenger side and all of the carpet and such was soaked. I've done everything I can think of to find the leak with no success. I THINK it's coming through the firewall, by the front right wheel well but I'm not certain. We've had record rainfall this month so I'm sure that didn't help.
Anyone experienced this problem or have any good ideas how I can locate the leak? I've tried pouring water over all the windows well checking for leaks in side.
Any help is very much appreciated. Thank you.
Banned
id pull all your carpet out so your down to just hte bare metal and make sure its all dry, and drive around like that for a few days, see what gets wet first, and maybe you can trail it back to the hole.
Did that, it looks like it's dripping down from under the dash, near the right front wheel well. Unfortunatly I can't see far enough up there to pinpoint exactly where it's leaking
Sounds like the heater core.
Is the water hot or cold?
Does it only leak when the heater or defroster is on?
The likely suspect, if not the heater core, would be the windshield. Examine the rubber stripping around the bottom of the glass to check for cracking and/or cuts. Also some shrinkage, I just got out of the pool, may have occurred.
Thanks for all your input folks, but nothing seems to be helping. I sprayed all the window seals, and the underbody on the passenger side and not a drop showed up.
Any other ideas? How can I determine if it was the heater core? Could it be an AC line? I don't know what to try next.
Banned
wow u really got me stumpped. do u have a sun roof? maybe its leaking in and running down. maybe your side windows it could be leaking and running down from there too im pretty stumped.
Only thing I can offer you is this. At work we basically have a shower head setup outside to put the car under to locate water leaks. What you'll need to do is have a second person to help you by standing outside with a water hose for a few minutes spraying that side of the car. You should first remove the passenger seat and peel up the carpet. Have the floor exposed and sit inside the truck with a flashlight while the other person is spraying the truck.
One more thing. A common water leak area is the door itself. Behind the door panel is a plastic sheet or foam barrier. If that is torn or missing you will have a water leak.
I've heard that water can get in between the windshield and the rubber gasket.Then later when it warms up, the water bubbles out on the inside.
1 - 11 of 11 Posts
