1 - 20 of 24 Posts
If the source is constant 12v (as in, voltage doesn't dip much under load) and you've got some diodes lying around, you can use them in lieu of a regulator. A silicon diode typically has a voltage drop somewhere around 0.7v. Put 4 of them in series and you're in business.
If you decide to use a regulator, something that looks like this will be cheaper and smaller than a switchmode DC/DC converter like the one q-ball posted.
I've been hackin' up old Cell phone car cords for my 12v to ???... Just an idea.
2020 Toyota 4runner TRDOR
you will probably find something similar if you crack open just about any dc voltage supply. the switched one you plug in to a car will have a resistor on each switch position to control the output voltage.
I built a voltage supply with one of those in junior college. use a potentiometer to adjust the voltage.
This specific model appears to have been made with semiconductors, but you're right; it can be done with resistors. The problem with using resistors is that they are sensitive to variations in source voltage, whereas regulators are more forgiving. It makes little difference in most automotive applications, because you already know the input voltage and the load.
This specific model appears to have been made with semiconductors, but you're right; it can be done just as well with resistors. The problem with using resistors is that they are sensitive to variations in source voltage, whereas regulators are more forgiving. It makes little difference in most automotive applications, because you already know the input voltage and the load.
that semi conductor is a voltage reg. you use a resistor to set the voltage on the control/ground leg (see page 8/40 of the PDF) The ratio of the two resistors you use sets the ratio of output voltage to input voltage.
trying to do it purely with resistors will yield a different voltage depending on the load you put on the circuit.
The voltage regulator will change its resistance electrically so the voltage doesn't change based on load.
one thing to add, your input voltage is NOT going to be 12v. with your charging system its going to be over 13.3v. use a DMM to check your source.
a lead acid cell is 2.1 volts. 6 cells in series is 12.6 volts. with the alternator running, your gonna be at a higher voltage so the battery will recharge. I believe it takes about 2.2 volts per cell to recharge a lead acid battery.
See if your camera supports above 9v.. Lots of the little mini surveillance cameras and video components, receivers, transmitters, hardwired cameras, etc.. that run on 9v batteries, always come with 12v AC/DC power supplies even though it says "9v" on the device it self. They may have their own regulators inside.
Ah I see what you're saying now: the resistor array is used to control the duty cycle of the regulator. I thought you were trying to say that the resistors did the work, so I tried to explain how that could be problematic under certain conditions, even with a constant load. My bad.
Depending on what type it is. The LDO regulator I posted can be likened to a resistor, but the device q-ball posted operates by opening and closing an electrical gate, so to speak.
Discussion Starter · #18 ·
Good call. I'll have to check. I completely forgot about that.
the alt puts out around the 14.4vDC its a range but thats the average for a charging system that is operating correctly.
1 - 20 of 24 Posts
