How does your clutch fluid look?
Also, how many miles since the last diff fluid swap?
This is true for the tranny but they are talking about the clutch fluid. I find it a bit odd if they use the same fluid for both the brakes and clutch and if so, I would be swapping that every 6months instead of my normal 12months.As far as I know the only fill plug is on the actuall tranny under the truck. I changed my own fluid and that is where I did the drain and fill from.
Gotcha, I read too quickly. ThanksThis is true for the tranny but they are talking about the clutch fluid. I find it a bit odd if they use the same fluid for both the brakes and clutch and if so, I would be swapping that every 6months instead of my normal 12months.
