1 - 7 of 7 Posts
Can i get a couple people that have this lift to measure the center wheel to the bottom of the fender well-front & rear?
Also people that are using 33's to measure from ground to top of bed/hood?
The Lift Kit is 4" R/ 5" F. Do they count the taller recommended tire. So its really a 3.5" lift or so plus the tire to make it 4" or 5" of lift, just curious?
Its professionally installed. Just like making sure mines similar to yours.
pretty much but I just ordered Radflos and UCAs from Greg today to with the aal and revolver shackles I have. It should put me at 44" ground to fender all the way around. I'll wait til they show up before I waste my time guessing the crossmember height.
Discussion Starter #6
So you both have 33" tires. So I will check your dimensions versus mine see if they are really close.
Ground to front fender- 40 1/4"
Ground to rear fender- 39 1/2"
Looks like the Calmini 4" lift in the rear & 5" lift for the front is counting the bigger wheel.
Thanks again.
wow all that money to get
1 1/4 higher then me in the front and
1/2 inch in the rear
and
lose 2 1/2 inches at the cross member im at 13
Breakover angle is a lot better with the Calmini 5" lift.
1 - 7 of 7 Posts
