With winter coming I'm looking for some clarification. This is the first true 4x4 that I've owned. Everything else has either been FWD or AWD. The manual says no dry road usage, I get that. The Frontier isn't in any danger of being confused as a 911 or an Audi so why would you ever need it anyway on a dry road anyway? If we have open diffs at the front and the rear (I have a CC SV) and the traction control is used to engage the second wheel on either axle then why would it matter if I used 4X4 Hi as long as I kept it under the max speed? Wouldn't just a single tire on each axle be engaged outside of a slipping situation anyway? Are the active and engaged wheels on opposite sides of the truck? Maybe that's a wheel speed difference issue. I ask because snow removal can be spotty up here so it would be nice to have in in 4 Hi when the roads are partially covered in snow but do not want to break anything. The Search function revealed a few threads but nothing definitive.
Locked transfer case. This is what makes it a true 4wd. An AWD car has a transaxle so the front 2 wheels can spin at different speeds than the rear. Thus if the traction control ninnies were not present only 1 wheel will spin if 3 wheels are 100% constrained.
So if you are in 4wh HI and making a U-turn, the front outer tire and the rear inner tire are spinning at dramatically different speeds. This will cause the drive train to bind and a tire to slip/chirp. However I would not worry too much about it. Sometimes in winter it is unavoidable to use or to leave your truck in 4wd. I take my truck up to 65mph regularly in 4wd hi. My wife did 75 unknowingly. I also make sharp turns in 4wd; slow speed parking lots. I took a picture of an example of a situation where this will happen. Though I did not need to here, often the pitch is opposite and I need to pull into drive isle as I am blocked the other direction. Getting out of such a parking space you NEED 4wd . Then you roll onto the pavement with the front wheels cranked. When that 2nd axle hits the pavement the drive train will bind and the tire will chirp. I'll do this 100 times a winter.
The reason you are instructed not to use 4wd on dry paved roads is that in 4wd (high or low), the front and rear driveshafts are locked together and will always turn at the same speed. However, when you are turning, or if there is any mismatch between front and rear tires (even if identical tires are worn more on one axle than the other), they will need to turn at different speeds. As long as you are on a surface that allows some slippage, this is not a problem, but on dry paving, it will cause tires to scuff and put a lot of strain on the drivetrain. As for patchy snow, as long as there is enough snow or ice to allow at least one wheel to slip frequently, you should have no problem with running 4 hi.
I have used my 4H in the rain for improved traction and drive-ability. Naturally there has to be slip for this to work. If there is insufficient slip, the steering wheel will twitch, tires will hop, so on an so forth.
Yup, sand sucks.. your speed. I've done the Great Sand Dunes park via Medano pass a few times and there's some soft sand in spots there. I usually run 4Low and lock the Elocker on the rear end, that way abs is off, seeing as I have a 6m it's also easier to pick a good gear and usually run 3rd through the sand so I still have some power to accelerate and yet still go somewhat slow, or drop to 2nd and have more acceleration but less speed. I'll also tell you that this is probably 8,000 feet up and the pass is around 10k at the top so the 265 hp becomes 201 hp there and 185 at the 10,000 foot mark.
You're not going to turn any better or brake any better with 4x4 in the rain. Not needed unless your one of those jackrabbit drivers...
As far as ice and snow, even patchy stuff I'd use it. It's fun at intersections when you can't hardly move because your rear tires are spinning and they have another 15 feet to go to get off the ice that accumulates at every red light during a snowstorm. 4x4 and your front tires are only a couple feet from excellent traction to get you moving through the intersection much quicker. So I'd engage 4x4 whenever stuck at one of those icy intersections and deal with 2 wheel drive any other time. I spent a few years up in North Pole AK and when I was there the roads were ice covered for months at a time, you'd get to driving so long on them that once the ice melted in the spring you'd realize you and everybody else were making up their own lanes that didn't always match with what was painted under the ice! I'd pretty much always run in two wheel and put it in 4x4 only at really icy intersections.
Now I have a full set of Firestone winterforce studded tires on a pair of stock steel rims I picked up in california for $50 for all four. Studs are hands down the best traction for icy/packed snow conditions so if you live West of the Mississippi then you might be in a state where they are legal. Here in Colorado they are legal year round but many states have only certain months where you can use them.
I am certainly not a jackrabbit driver. Through experience I have found 4WD in heavy rain give me the fishtail protection I want. There have been many times that when driving in rain, I sense the rear swinging around. This does not happen in 4H. There is no binding as there is ample slippage. So if it helps, why not do it?
I also didn't understand why it would bind even though we have open diffs in the back and front. I come from AWD cars and this is my first 4WD truck...
Thanks everyone. I'm going to go ahead and use it when the roads are icy or partially snow covered. Does it throw off the handling on icy surfaces when the drivetrain is trying to "un-bind" after a corner? .
Both pumpkins are open diffs. Therefore there is no confict intra-axle. The transfer case will deliver power with the proviso that each axle has the same rotational speed. Bottom line: so long as one wheel has slip, there is no binding. This is often the case with icy and snowy conditions. I have seen it with heavy rain conditions. You want 4WD because it prevents the rear axle (RWD) from swinging out causing a spin out. If you feel the back end slipping out of control in 2WD, it is too late to engage 4WD.
just drive in 2wd. if you start to slip and slide then put it into 4hi. if it's patchy such as dry parts of the road and snowy parts try to put it back into 2wd if the turns are dry areas. going straight it doesn't matter so much. on a snowy turn leave it in 4hi. on dry turns put it in 2wd.
4lo is good for going down snowy hills. shift into 1st or 2nd gear and just go down the hill never touching the brakes or gas. it will keep your speed in check for you and you don't have to hit the brakes and go sliding into a ditch.
Lol....some folks think that driving on a smooth gravel forest service rd is real 4wheelin.If you can be at 45mph there's not much reason to even be in 4wd.I would usually be in low gear at less than 10mph if I really needed 4wd.
If you can drive around fine in 2WD, 2WD is the correct choice.
If you are on a snow covered road where 2WD won't get you around, use 4WD.
It's common to use 2WD in the winter most of the time where the roads are good, but grab 4WD to get up the driveway that is still snow covered.
This discussion reminds me of a feature I'd like to see on the 3rd gen Frontier - a full time 4wd mode (i.e. 4 auto). You would have a clutch pack in the transfer case to allow for differential rotation between the front and rear drive shafts. This way, you wouldn't have to turn off 4hi in order to make turns on dry pavement. I think all GM vehicles with 4wd have this type of transfer case.
Related Threads
Nissan Frontier Forum
1.9M posts
113.3K members
Since 2005
Welcome to our Nissan Frontier Forum! A premier community to share your mods and builds. Chat with like-minded Frontier owners.
