1 - 8 of 8 Posts
I am seriously thinking on buying a 2" leveling kit, would this kit leave my truck completely level with rear or must I use some other Item to level it.
yes, i got 3/2 and my rear is 1 inch higher... 2 in the front will level it out..
i think its fine too. also depends on what you consider level. if the front and rear wheel wells are the same height, then the bed is very slightly raked forward. if the front wheel well is 1" higher than the rear, then the bed looks level.
Discussion Starter #5
goood, Thank all...
I would recommend the leveling kit from TopGunz Customs. It is less than $100 with shipping and was abreeze to install.
Idk, I did the 2" level in the front and a 1" block in the rear and the truck looks perfect, imo. Without the 1" in the rear, it appeared to sit higher in the front, which looked kinda wack...imo. :)
1 - 8 of 8 Posts
