1 - 4 of 4 Posts
Could someone please tell me what does the indicator look like and where on the cluster is this light located? I noticed that my truck does not show any indication when in 4HI or 4LO. I tested the 4x4 system this past snow and it does work. Thanks.
Well I have 2wd (same cluster) just shined a flash light at my cluster and it's the second display on the top row of the lower left corner of the cluster, just left of the low fuel indicator
It looks like a picture of a bare frame with a driveshaft straight through and wheels at each corner and a little box where the transfer case is
thanks. my bulb must be out (if that's even possible). I can leave the trans in park and shift the transfer case into neutral and the ATP light shows. So that must mean the switch and wiring is fine to the transfer case.
1 - 4 of 4 Posts
