While flipping through the manual, I came across information that I wasn't aware of.. My truck wont need a NYS Emissions test until 2012 -- but I noticed this warning in the Nissan manual:
Do not attempt to test a 4WD equipped vehicle on a 2-wheel dynamometer (such as the dynamometers used by some states for emissions testing), or similar equipment even if the other two wheels are raised off the ground. Make sure you inform test facility personnel that your vehicle is equipped with 4WD before it is placed on a dynamometer. Using the wrong test equipment may result in drivetrain damage or unexpected vehicle movement which could result in serious vehicle damage or personal injury.
New York State says that the dyno emission testing requirement is waived in the following conditions:
Vehicles that lack the ability to disable four-wheel drive, all-wheel drive, or traction control are exempt from the transient test (instead, the vehicle just gets an idle test)
Now.. I know VDC can be turned off, but that doesn't turn the ABLS system off.. But I was also reading that (if I am reading it correctly) ABLS is not active in 2H mode:
On 4WD models the ABLS system operates in both 4H and 4LO modes. If 4WD mode is engaged, the ABLS system will operate for both drive axles. On 2WD vehicles, the ABLS system operates on the drive axle only.
So here's my question.. I'm concerned that an inspection station may run the truck on the single axle dyno, despite Nissan's warning not to do so. Is this a real concern? What can happen? Obviously, I would likely ask the shop not to do it, and point out the section in the manual saying it can cause vehicle damage.. Has anyone had any real experience with this in New York or any other state that does two-wheel dyno emission tests?
Thanks,
Rick
Thanks,
Rick
