It seems this time that my oil filter housing is leaking on the opposite side of the filter. Can this be replaced or should it had been taken off during this job?
STFU!!!!
Just go some where else! This is crazy! A monkey could screw up that much.... and he would do it for a few bananas! Crist that place sounds like a mess!
did you put a bit of oiil around the gasket when you put the filter onI'm trying to figure out if the piece the oil filter is screwed on is replacable . That is where it is leaking from . Everything else is clean and dry under there. If I can get that part I may just fix it myself
