1 - 3 of 3 Posts
has any installed this kit from nissan? do you need to install the relay jumper? or can i just install the harness jumper? if i install the relay jumper it hooks up on the right side kick pannel, then i take that pannel off there in a harness that is not hooked up i belive thats the one that it goes hooked up to am i right with this?
the thing is that i hooked this up and it seems that today i found the brake light fuse blown . i could use any feed back on this. thanks to all
yes, i know. if ita man. then you use 3 relays, auto you use 2. but that are they for? trailer brakes? i donot tow anything that big to use trailer brakes. so do i need to hook up the hearness with the relays? and just use the one under the bumper?
1 - 3 of 3 Posts
