1 - 14 of 14 Posts
I'm selling four 18" rims that I took off my Frontier when I swapped to Titan parts. I have a few pictures of them on the truck in my gallery, feel free to check them out. They aren't mint condition, in fact two of them are missing the plastic center cap but still look nice.... especially for the price. I'm sure they're not cheap to ship so the closer to Ogden Utah you are, the better.
I also have two more of the same rims with Titan bolt pattern that are in very good shape if you've done a titan swap on the front.
Two of the rims have tires on them cause when I did the Titan swap on the front, I bought two more of the same rims with Titan bolt pattern and put the tires on them... I'm also selling the Titan rims. The two without tires on them are missing the plastic center caps, I'm not sure on the back spacing, probably same as factory. I suppose I could take the tires off, they are bald anyway. The rims are 25 pounds each and are in Ogden Utah.
Discussion Starter · #10 ·
Here's some closer pics of each Frontier rim. They are definately not mint... I probably should have cleaned them first, Oh well
Here's pics of each Titan rim.
Discussion Starter · #12 ·
Your truck is crazy sic! Whats up? You selling the truck? Did the wheels stick out further then stock? Thats what I meant by off set.
LOL! I'm NEVER sellin this truck. It's my youngest son. The rims are stock backspacing and offset as far as I know, the offset you see in the pictures comes from the Titan front end. That's why it's not offset in all the pictures. The Titan Suspension and axles add 3" on each side. Since the Titan and Frontier have the same Dana 44 rear end I just put 3" spacer/adapters on the back so I can just run all Titan rims so I can rotate tires again. The black rims on there now are just stock Titan rims I painted with a rattle-can.
Discussion Starter · #14 ·
1 - 14 of 14 Posts
