1 - 8 of 8 Posts
I'm not sure what you mean but the spacers have their own lugs
The stock lugs on the truck are just over 1" long so most spacer/adapter requirements are a minimum of 1.25" to ensure the wheel will sit flat against the adapter when intalled. If it is only 1" thick, you run a risk of the wheel impacting the OEM lugs and thus, not sitting flush. Now, if they took then into consideration when building the wheels, they may have machined out a little more on the backside but without the wheels infront of me, I can't tell you for sure.
your selling 4 rims right?
where are you located?
1 - 8 of 8 Posts
