1 - 7 of 7 Posts
Hey folks. Just wanting to post this here as an option for owners who are hesitant to jump to a 33 right away.
My goal for next year is to upgrade to a full suspension lift, but the factory rake kept bugging me so I picked up a leveling kit from Z1 Offroad in the meanwhile. On a whim, I started searching for lightly used tires off of FB Market and scored a great deal on a set of five take-offs from a local Jeep gal.
These are 255/75/R17s and they amount to a 32.1-inch tire. This is apparently the factory size off of the Willy's edition Wranglers and Gladiators, and a lot of owners upgrade to a larger size almost immediately, so there are usually tons of these being sold on FB. The set I bought only had 100 miles on them and were so new they still had the rubber whiskers on the outside.
Considering the popular 285/70/R17 comes out to roughly 32.8 inches, these aren't all that far off. You do lose some width though, so you'll have to be a fan of the skinny look. I'll jump to a 80-ratio tire in a year or two to get a true 33, but these will be fine for now.
No rubbing, but my madflaps were the first things to go when I got the truck. I'll also add wheel spacers soon to widen the stance a bit, but here you are in the meanwhile.
Wheel Tire Vehicle Car Hood
Tire Wheel Vehicle Car Motor vehicle
Tire Wheel Vehicle Automotive lighting Automotive tire
I've ran the same size tires for years. Previously on a 5th gen 4Runner and currently on my Frontier. As you note, this is the stock tire size on many wranglers which really helps us out since they are available as c-rated, so much lighter than e-rated alternatives. Jeep has also helped us out with 285/70 17s, which are now available in c-rated options too. But as you note, the 255/75 tire size is just slightly larger than stock while not being too much heavier.
Thing to note, if you do move to 255/80, all of those options are e-rated i believe. You'll gain ~7-10lbs PER TIRE from the current size you are running. That's quite significant when you consider the 255/75s are already about that much over the stock tires.
· Vendor
2022 Nissan Frontier PRO-4X
Love the look and setup!
2022 Nissan Frontier King Cab 4X4
Your truck looks great. A favor though. Would you take a picture of the front tires looking rearward? I am trying to gauge the stance from the front. I am becoming more and more interested in these pizza cutters!
Reactions: Frontiermedic248
1 - 7 of 7 Posts
