So I am about to do the 30k mile service, and I noticed that the Haynes Manual I have lists more items to be replaced than Nissan requires, or at least I think they do...
Here is the Nissan list I found:
Nissan Vehicle Maintenance Schedules - Nissan USA
Basically, the main stuff seems to be ATF change, Diff fluid change, Xfer case change, etc.
But Haynes says to:
1. Change Brake fluid
2. Replace Spark plugs
3. Change ATF And filter
4. replace PCV valve
I have skipped listing a few items b/c the items either overlapped with Nissan, or where to be checked, not replaced.
So which Service did you guys do? I know that the "better" way to go would be doing more service, and replacing more, but is all this really necessary?
Thanks
But Haynes says to:
Thanks
