1 - 2 of 2 Posts
So the pinion bearing went out in my frontier 2wd ext cab 5 speed if that matters getting a moaning and slapping sound no luck finding the internals for the rearend anyone lnow of where i can order a complete rebuild kit for the rearend pinion bearing gears and all or would it be cheaper to swap out with a Toyota rearend and have a slip yok put in and driveshaft set to fit thrn redrill front hubs
Looks like Rockauto has them for my truck; hopefully they'll have yours too.
How many miles? I'm not sure if my differential is getting noisy or if it's the tires. Mine has 107k.
I've been looking around at axle swaps for lsd, but I want to keep my abs functional and I think that limits me to an 04 Frontier 6cyl 2wd, unless the sensor rings can be swapped out then other years and even xterras may work.
1 - 2 of 2 Posts
