Lift and the adjuster bolts is all you should need but you might want to check the rest of your suspension parts for any wear and tear while you are in there, especially if you have a good amount of miles onit. Should look good. I'm about to do mine soon I think. Original tires are getting close to being shot (finally)!!! I hated the idea of buying new tires and not getting all the use out of the first set.
