1 - 4 of 4 Posts
Anyone have a good explanation of what needs to be done in order to remove the either driver or passenger head lights from the body of the 2nd gen frontiers? Theres a little modding I have in mind, before destroying shi* I guess it'd be a great idea to get some headlight removal advice from somebody who's already done it before, anyone pointing me in the right direction in very appreciated!
thanks
-steve
its been a while since i took mine off but if i remember right there are about three bolts that you cant really see. i think there are two facing outside and i think one on the bottom. i was removing my whole front bumper, so wasnt too observant on bolt placement. i think there are a total of five bolts. it really depends on how in depth you want to go. hope this helps.
this is information from the service guide i have on my computer.
headlamp removal
REMOVAL
1. Remove the front bumper. Refer to EI-14, "Removal and Installation" .
2. Remove the headlamp bolts.
3. Disconnect the headlamp connector.
front bumper removal
Removal
1. Remove radiator grille. Refer to EI-19, "FRONT GRILLE" .
2. Remove front valance LH, center, then RH.
3. Disconnect front valance lower from engine undercover.
4. Remove front bumper stays LH and RH.
5. Disconnect fog lamp harnesses, if equipped.
6. Remove front bumper reinforcement stays RH and LH.
7. Disconnect front fender protector and front bumper upper valance from fender.
8. Disconnect front bumper upper valance from front bumper bracket center.
9. Remove front bumper assembly.
Installation
Installation is in the reverse order of removal.
front grille
REMOVAL
1. Release upper clips from front grille.
2. Twist and release LH and RH side clips and remove front grille from member.
INSTALLATION
1 - 4 of 4 Posts
