1 - 2 of 2 Posts
Hey everybody,
I found a good deal on an OEM bed extender. It is off a 2007 Frontier (2nd Gen) and I have a 2003 Frontier Crew Cab Short Bed (1st Gen). Also, I do not have UtiliTrack.
Will the bed extender fit my truck? I don't want to have to make any time consuming modifications. Otherwise, I'd just buy a new one.
Thanks!
If it was built for the utilitrac then it will not work without some semi-major modifications.
If it is the stationary mount, then it would only require semi-minor modifications.
Also, check the width of your bed compared to a 2nd gens. You need to be equal or greater for it to fit. If you are skinnier, then you would have to add material to make it fit instead of removing material (cutting down the center pipes).
1 - 2 of 2 Posts
