My intention was not to use LED or even post regarding this change. But my a/c controls have not been backlit for a few years. I had the dash apart for other reasons and finally decided to replace the bulbs. Only to find the bulbs are soldered to the circuit board. I then decided, if I have to use a soldering gun I might as well try to use a few of the LEDs I have laying around the shop.
I soldered a 2k resistor and used heat shrink, because that is what I had on hand, different resistors may be more ideal. Overall I am pleased with the outcome and it only took about 30 minutes. I had to line the LEDs in the exact same position so they would fit where the bulbs were originally. At first my LEDs were too bright and caused a bright spot at each location. So I used a sharpie to dull the brightness and allow it to disperse more evenly through the controls.
It is not perfect and I am not sure how long it will last, but since I have been with out lights on the A/C controls for a few years I figured it can't hurt.
