1 - 20 of 21 Posts
2nd Gen (2005+) FAQ Part 1 [Updated 05-03-12]
This FAQ will hopefully have answers to some of the more commonly asked questions. Please add your input and correct me if anything I have written is incorrect. I will edit the original post with any new information.
2005+ Nissan Frontiers are referred to as 2nd Generation Frontiers
WEBSITES that have Nissan and 2nd Gen related products:
Site Sponsors:
4X4 Parts: https://www.4x4parts.com/nissan/
Agri-cover: Agricover.com: Truck Bed Covers and Caps - Pickup Tonneau Covers
Airaid: AIRAID Filter Company
Calmini: CALMINI Products Inc. - Suzuki, Nissan, Isuzu Suspension Systems and Lift Kits
Discount Tire Direct: Home - Discount Tire Direct
Fontana Nissan: Nissan Performance Aftermarket Parts | Nismo | Nissan Racing Parts
MGT Motorsports: MGT motorsports Blendmount
NissTec Lifts: Home - Nisstec Lifts: Nissan Lift Kits: XTerra Lift Kits, Frontier Lift Kits, Titan Lift Kits, Nissan Truck Lift Kits
NOPI: Official NOPI Custom and Performance Auto Parts Since 1966
PRG Products: PRG Products
RockAuto: Auto Parts Fast at RockAuto
Shrockworks: Bumpers, Rock Sliders, Rocker Protection, Skid Plates, ShrockWorks
Superchips: Superchips / Home / www.superchips.com
TruckXL: TruckXL, Inc. | #1 in Truck Accessories and Truck Parts | Philippians 2:3
Other Websites:
Tactical Armor Group: :: Tactical Armor Group :: Store
Hellwig Products: Hellwig Products
Trail Gear: Welcome to Trail-Gear Inc
Total Chaos Fabrication: What's New
Calmini: '05-'08 Frontier
Fabtech Motorsports: http://www.fabtechmotorsports.com/html/home.html
CST Performance Suspension: http://www.cstsuspension.com/product...ID2/8/sfID3/47
Truxxx: http://www.truxxx.com/store/index.ph...ex&cPath=36_46
Ready Lift: http://www.readylift.com/c-109-front...8-2wd-4wd.aspx
4Crawler Offroad: http://www.4crawler.com/4x4/ForSale/...ehicleProducts
Rancho Suspension: RANCHO Suspension - Nissan
Daystar: http://www.daystarweb.com/Categories...1-23d928237d79
Alcan: Alcan Spring - Manufactures Fine Custom Leaf Springs
Deaver: Deaver Suspension
Shock Warehouse: Bilstein - KYB - Rancho - Monroe - Edelbrock Automotive Truck Shocks and Struts - Shockwarehouse.com
Revtek: Revtek Suspension | Nissan Suspensions
Eaton/ Detroit: Welcome - Eaton.com
ARB: ARB Air Locker Heavy Duty 4x4 Bumpers
TJM: TJM - Serious 4WD Equipment > Home
Unichip: Automotive Performance ECU Tuning Chip, Programmable OBD Chips
Uprev: UpRev - Engine Management
Bully Dog: Bully Dog Technologies - #1 In Performance.
Stillen: STILLEN : Precision Performance Components for Your Car or Truck
Sun Performance: Sun Performance
Hypertech: Hypertech, Inc.
Banks Power: Banks Power | Diesel Performance and Gas Performance Products
FRONT SUSPENSION
The 2nd gen frontier has a coil over front suspension.
There are replacement UCA’s (upper control arms) available from PRG Products, Total Chaos Fabrication, and Calmini.
*Also see JeniorNV’s Suspension Sticky here: JeniorNV's Suspension Sticky
FRONT LIFT OPTIONS FOR 4x4 TRUCKS
There are many different configurations/ products used to lift the front, I will highlight the basics.
*(It’s not advised to go higher the 3 inches without a drop bracket lift).
Spacer Lift:
Used to raise the truck 2 or 3 inches. The coil spacer is usually placed on top of the shock assembly. (NOTE: There will be coil bucket contact especially when using a 3 inch spacer. Aftermarket UCA’s are recommended for a 3 inch spacer)
Replacement Coil Over’s:
The most common is the Radflo replacement coil over from PRG Products. With stock UCA’s (upper control arms) they will give you up to 2.5 inches. If you get aftermarket UCA’s you can get up to 3.5 inches of lift. Total Chaos also has a kit which includes Fox coil over’s.
Drop Bracket Lift:
Calmini and Fabtech are the companies you can get a drop bracket lift from. The Calmini kit is a 5 inch lift, while the Fabtech kit is a 6 inch lift. These lifts require you to lower the differential (to keep good angles of axles, etc ) and both require some modification (read: cutting) to be installed.
Titan Swap:
The Titan front suspension components are used to help gain more travel (1.5 inches). This will widen the front by 3 inches per side. (I need more info on what parts are needed for the 4 wheel drive swap, but here is what I think is needed) Parts needed for this swap are UCA’s, LCA’s (lower control arms), tie rod extensions, extended axles, extended brake lines, and new coil over’s.
FRONT LIFT OPTIONS FOR 4x2 TRUCKS
Spacer Lift:
Used to raise the truck 2 or 3 inches. The coil spacer is usually placed on top of the shock assembly. (NOTE: There will be coil bucket contact especially when using a 3 inch spacer. Aftermarket UCA’s are recommended)
Spindle Lift:
CST spindles will give you 4 inches of lift and they replace the factory spindles. You can also add a spacer or coil over’s to this to get up to 7 inches of lift. If you go above the 4 inches you will need extended brake lines.
Drop Bracket Lift:
Calmini and Fabtech are the companies you can get a drop bracket lift from. The Calmini kit is a 5 inch lift, while the Fabtech kit is a 6 inch lift. I’m not positive, but there should be less modification needed since the 2 wheel drive trucks have no front differential.
Titan Swap:
The Titan front suspension components are used to help gain more travel (1.5 inches). This will widen the front by 3 inches per side. Parts needed for this swap are UCA’s, LCA’s (lower control arms), tie rod extensions, extended brake lines, and new coil over’s.
REAR SUSPENSION
The rear suspension is a spring over axle suspension. This means that the spring pack sits on top of the axle, and as a result our spring packs are pretty flat looking right from the factory. NOTE: It is recommended that you get longer shocks when lifting the rear, although the stock shocks will be ok for up to 2 inches of lift.
REAR LIFT OPTIONS:
(You can combine blocks, shackles, and AAL’s in various combinations to achieve your desired height)
* 6-speed 2wd Frontiers that want more than 4" of rear lift need a carrier bearing drop bracket.
Blocks:
Blocks are a piece of aluminum or steel that goes in-between the axle and the leaf pack. They usually provide between 1 and 3 inches of lift. This is the easiest way to lift to lift the rear of the truck. One downside to blocks is that they can increase the chances of axle wrap. Axle wrap is caused by torque of the rear wheels twisting the leaf springs, which will make the rear end hop under acceleration.
Shackles:
You replace the factory shackles with ones that are longer. They provide 1 to 2 inches of lift. These are also fairly easy to install and will give you more flex than blocks or Add-A-Leaf’s.
Add-A-Leaf (AAL’s):
With an AAL you add leaves (2 to 3 leaves depending on which brand you buy) to your leaf pack. The added leaves raises the rear of the truck. With some AAL’s you may need to remove the stock overload leaf. Most people say this is the best way (without getting a full leaf pack) to lift the rear and will often add shackles if they need more lift.
Full Leaf Pack (custom):
This is probably the best way to lift the rear, but it’s not the most cost effective. I believe they run about $600 and they can be ordered from Alcan Spring or Deaver Spring. They may also need to know specific measurements and what you are using the truck for so they can build you the correct pack. (Alcan should know our measurements by now since I believe a few people have ordered custom packs.)
Post #2 has Part 2 with more info
Discussion Starter · #2 · (Edited)
2nd Gen (2005+) FAQ Part 2
BODY LIFTS
A body lift raises the body of the truck giving it the lifted look while the suspension and frame are still at the same stock height. The advantage with a body lift is that it allows for bigger tires. Body lifts are typically less money to purchase, but are more work to install. You can get a 2 inch or 3 inch body lift from 4x4parts.com with everything you need included. There is also the option to make your own body lift. Here is the thread with all the info you should need http://www.clubfrontier.org/forums/f23/diy-2-body-lift-19685/
Some basic wheel info:
Titan wheels (or any 6x5.5 wheel) will not fit on a 2005+ Frontier without wheel adapters.
You can get high quality wheel adapters from WheelAdapter.com is your number one source for wheel adapters, wheel spacers, used wheels, and wheel studs.
Wheel bolt pattern is 6x4.5 or 6x114.3mm
Factory wheels have an offset of +30
Stock XE/S:
Wheel size is 15 inches
Wheel width is 7
Stock SE/SV and NISMO/PRO-4X:
Wheel size is 16 inches
Wheel width is 7 inches
Stock LE/SL:
Wheel size is 17 inches
Wheel width is 7.5 inches
**The most common and easily fit tire-size is 285/75/16 and it usually requires at least a 2" lift. It's roughly a 33" tire and it keeps the stock rim size for SE/SV’s and NISMO/PRO-4X’s.
TIRE SIZES
There is no clear cut answer for the biggest tire you can run. There are so many variables with rims and tire widths, etc. that it is difficult to say exactly what will fit. Most people run a maximum of a 33 inch tire. To fit this they usually have some kind of lift and will remove the front air dam and sometimes the mud flaps. Some tire/ wheel combo’s also require you to remold the inner fender plastic lining using a heat gun. Sometimes modification of sheet metal may be required.
REAR AXLES
XE’s/S’s have a C200?
LE’s/SL’s and Auto SE’s/SV’s have a C200
Nismo’s/PRO-4X’s and manual tranny SE’s/SV’s have an M226 (bastardized Dana 44)
AXLE RATIO’S NOTE: *May not be accurate for S models with V6 and/or SV models wit 4 cyl. I’m trying to verify data*
Model Axle Gears
XE/S/SV 4 cyl KC 4x2 5M C200 4.083
XE/S/SV 4 cyl KC 4x2 5A C200 3.692
SE/SV KC 4x2 6M M226 3.538
SE/SV KC 4x2 5A C200 3.133
SE/SV KC 4x4 6M M226 3.538
SE/SV KC 4x4 5A C200 3.133
SE/SV CC 4x2 6M M226 3.538
SE/SV CC 4x2 5A C200 3.133
SE/SV CC 4x4 6M M226 3.692
SE/SV CC 4x4 5A C200 3.357
NISMO/PRO-4X KC 4x2 5A M226 3.133
NISMO/PRO-4X KC 4x4 6M M226 3.692
NISMO/PRO-4X KC 4x4 5A M226 3.357
NISMO/PRO-4X CC 4x2 5A M226 3.131
NISMO/PRO-4X CC 4x4 5A M226 3.357
LE/SL KC 4x2 5A C200 2.937
LE/SL KC 4x4 5A C200 3.133
LE/SL CC 4x2 5A C200 3.133
LE/SL CC 4x4 5A C200 3.357
Please note that the gearing may not be accurate for LWB models, the specs I am using do not include LWB, so I do not know if they are geared lower to make up for the weight increase. However, the axles will be the same.
Limited Slip Differential's (LSD) and Lockers:
In an open differential power goes to the wheel with the least resistance. In low traction situations this means that a wheel that is slipping is getting a the power. An open differential allows opposing wheels to move at different speeds when taking a turn (the inside wheel moves slower than the outside wheel in a turn). An LSD will help with gaining traction when one wheel starts to slip. It will automatically transfer some of the torque from a slipping wheel to the opposite wheel granted it has a chance at having traction.
A locker will split the power between the wheels 50/50 no matter what the traction situation is. This is the ideal solution for traction off road since both wheels are getting power. Most people today seem to opt for a selectable locker (whether by air, cable, or electric) if there vehicle is also driven on the street. This gives them the option to return to having an open differential for driving on the street.
For trucks with the M226 axle an LSD (The Detroit TrueTrac made for the Titan M226) and a locker (ARB air locker) are available.
For trucks with the C200 axle, I'm pretty sure one is avaialable, but will update when I get a chance to look the info up.
TUNERS/PROGRAMMERS
**Some of the programmers do not work on 2011+ Frontiers and/or 4 cylinder models. Visit the manufacturers' websites to see if they will work for your application**
There are a few options for getting programmers to increase performance. Uprev reflashes the stock ECU and the most custom tune. It can become expensive if you get the Osiris/Cipher PC based reflash software and data logging software.
The other programmers are Plug and Play (you plug an external device into the truck) and they are a more generic tune. They include the Superchips Cortex (which at the moment is the most popular), Unichip Plug N' Play, Bully Dog Power Pup, and Hypertech Max Energy.
FLUIDS and CAPACITIES (According to the Amsoil Product Guide)
VQ40DE [V6]
Cooling System:
11 Quarts for the Initial Fill
Engine Oil with Filter:
API SAE 5w-30, 5.4 Quarts
Manual Transmission:
GL-4 75W-85 (Nissan recommends their MTF HQ Multi 75W-85 Part# 999MP-MTF00P)
6 speed 4x2 takes 4.2 Quarts
6 speed 4x4 takes 4.45 Quarts
Automatic Transmission:
Genuine Nissan Matic J Trans fluid, 11 Quarts for a total fill
Front Differential (R180A):
GL-5 80w-90, 0.95 Quarts
C200 Rear Differential:
GL-5 75w-90, 1.7 Quarts
M226 Rear Differential:
GL-5 75w-140 (*Synthetic Required), 2.1 Quarts
Transfer Case:
Nissan Matic D or DEXRON-III/MERCON, 2.1 Quarts
QR25DE [I4] (I assume the Rear Diff is a C200, but I haven’t confirmed it)
Cooling System:
10 Quarts for the Initial Fill
API SAE 5w-30, 5.2 Quarts
GL-4 75W-85 (Nissan recommends their MTF HQ Multi 75W-85 Part# 999MP-MTF00P), 3.05 Quarts
Good Evening. Does anyone have any updated specs for the new 2011? Would the SV fall under the SE line for line, or were things changed? 3.538 gear ratio for my truck?
Should be the same as the SE including gear ratio. The only changes should be interior and exterior appearance changes.
I'll be updating this with the new models in the very near future.
Great info, but I have an 05, and I'm pretty sure that the stock front suspension is struts. This post refers to coil-overs, but a true coil over design has a shock with a spring fit over it, which can be taken apart by taking the load off the front suspension. If they're struts, you need a spring compressor. Trying to take the strut assembly apart without a proper compressor is extremely dangerous, as I hope we all know. Thanks again for the info.
What is the difference between the C200 and the C200k? Where is the C200K used? I ask because ARB has two different lockers listed for these two rear axles.
To answer my own question. The C200 was on the first gen frontier and the C200k appears to be on the second gen frontier.
1986-97
REAR C200, 29 SPLINE, 4 CYL.
1998-04 REAR C200, 31 SPLINE
2005-14
REAR C200K 31 SPLINE
ARB Air Lockers for Frontier 2005-2014 Part Numbers
M226 32 Spline Rear Axle 10-bolt # RD149
C200K 31 Spline Rear Axle # RD196 (will not fit 4cyl 4.10 gear set)
R180A 27 Spline Front Axle # RD180 (3.69 & up ratios)
R180A 27 Spline Front Axle # RD181 (3.54 & down ratios)
Yes...they changed the front end in 2009. Also, keep in mind there are both chrome and painted plastic bumper covers for each of those years, with the 2012 plastic bumper covers have a textured section on it.
The Midnight Edition only goes on the SV trim level and mandates the VTP also be purchased/installed.
Looks like the previous owner painted the grill black and installed some black "aftermarket" wheels.
Depends on the year. Nissan used Nissan green coolant, which is actually Pentosin Pentafrost A2 anti-freeze, up to 2010, when they started phasing in Nissan blue, or Pentosin Pentafrost A3 coolant.
Site Sponsors:
Other Websites:
FRONT SUSPENSION
Spacer Lift:
Drop Bracket Lift:
Titan Swap:
Spacer Lift:
Spindle Lift:
Drop Bracket Lift:
Titan Swap:
REAR SUSPENSION
REAR LIFT OPTIONS:
Blocks:
Shackles:
Add-A-Leaf (AAL’s):
Thanks
1 - 20 of 21 Posts
