Anybody running either 275/65-17 BFG AT or Yokohama Geolander ATS on stock 17" LE rims at stock height.
How much trimming/molding etc did you have to do, if any?
Stock tires are 265/65-17 BFG LongTrails. Look like they have plenty of room to go to the 275's
Thanks. Jim
Rogue Admin
2007 LE 4x4 Crew Cab Long Box
first i heard they made this size. perhaps the front valance will have to go, and maybe trimming of the mudflaps if you have them.
Rogue Admin
That is barely any larger than the OEM size. I doubt any trimming will be needed.
It is only 1/2" taller and a little less than 1/2" wider.
yes, but the ATs are a very square tire. Be intersting to see how they turn out
i am running 265/70 R17 TGs and did not need to trim anything
if you can find a tire that size, it should fit. hopefully trimming should be very very minimal if any.
like mandangalo i am running 267/70/r17 tires on stock LE rims and i did not experience any rubbing of any kind. the size you are looking at is basically "shorter" but a bit wider...
