1 - 20 of 24 Posts
Funny...I was thinking the same thing...
But I only want to put on OEM 20's or 18's from the Armada, or Infiniti QX56 in chrome. Not many after market rims I like, but normaly i am a fan of factory chrome rims.
I am not going to outright bash the 20s but just make sure you get them with tires that are rated to support the weight of your truck with its max bed weight and towing weight so that if you are put in the situation in which you need to fill the bed and tow something, you don't just pop the tires.
Also, think about the roads in which you drive. If there is a ton of potholes, then you may want to consider the 18s so there is more give in the tire.
only issue with those is you need an adapter to make them fit different bolt pattern
Oh damn...I thought I read it was a straight bolt up...in that case forget it.
I have 20s, just check out the avatar. i think thats what its called.
word
Hey im actually getting the KMC Rockstar XD 775 20" wheels for my truck along with a 3" leveling kit. and i did put 285/50/20 falkin s/tz-04 rubbers on it.
so it should nt look too bad right. this is just the beginning of my mods i have planned. Godd luck with your rims.
1 - 20 of 24 Posts
