Try hooking the radio to a stand-alone battery and see what the rest is. Sounds to me like your radio's bad.
Try hooking the radio to a stand-alone battery and see what the rest is. Sounds to me like your radio's bad.Hello,
I'm not new to CB installations but this 2023 truck has me stumped. I wanted to use the 12v outlet to power the radio but don't know what the amp rating is and can't find it anywhere. I temporarily hooked up power direct to battery and have the same problem. When I transmit all it does is buzz on the receiving radio. Usually that indicates not enough power to drive the transmitter, but I had it direct to the battery with same result unless my connection wasn't very good. Has anyone encountered this kind of problem?
regards to all,
Rich
In the second Gen it's 20a, I would expect the 3rd to be the same.Does anybody know what the 12v outlet amp rating is?
Agreed. I have had CBs in several vehicles and never observed this type of behaviour.Not to ask the obvious but, do you have the CB antenna connected to the unit when you try to transmit? The standard 12v socket should have more than enough power for just a CB, I don’t think lack of amperage is your issue here.
Have you popped a voltmeter on that 12v outlet? Possible there's an under- or over-voltage situation and it's zorched your radio?Yes of course. And yes, I agree there should enough power from outlet. I'm going to try the separate battery idea just to see what happens, this is very puzzling. What is also weird is that when the cell phone charger is plugged in to the outlet sometimes it works and sometimes it doesn't. This is a brand-new truck got it in February.
thanks,
The fact that a different device gives you intermittent functionality makes the outlet suspicioso.Yes of course. And yes, I agree there should enough power from outlet. I'm going to try the separate battery idea just to see what happens, this is very puzzling. What is also weird is that when the cell phone charger is plugged in to the outlet sometimes it works and sometimes it doesn't. This is a brand-new truck got it in February.
thanks,
I don't think it would be that sensitive to scorch a CB... unless you're talking like, mega high voltage. Plus - don't most CBs have a fused power line?Have you popped a voltmeter on that 12v outlet? Possible there's an under- or over-voltage situation and it's zorched your radio?
A fused line would only protect from overcurrent, not overvoltage, technically, but I can't see what in a 12v system could be voltage over and above operating standard that could be sourced from anything reasonable. Even an alternator full-fielded will rarely go above about 16.0-ish so yeah, it's theoretically possible but you'd see a whole raft of other things going on too, bulbs flaring brightly or burning out, other electronics impacted, etc, just doesn't sound very plausible.The fact that a different device gives you intermittent functionality makes the outlet suspicioso.
Like the suggestion above, I'd say try a completely different car battery. If the radio still does nothing, there's the answer.
100% agreed. My bet is on equipment, not power source.A fused line would only protect from overcurrent, not overvoltage, technically, but I can't see what in a 12v system could be voltage over and above operating standard that could be sourced from anything reasonable. Even an alternator full-fielded will rarely go above about 16.0-ish so yeah, it's theoretically possible but you'd see a whole raft of other things going on too, bulbs flaring brightly or burning out, other electronics impacted, etc, just doesn't sound very plausible.
I think the radio or the antenna's at fault until some other interesting evidence is provided.
Easiest/most practical way is through the firewall on the left side of the truck. Next to the master cylinder, you'll see the main harness pass-through plus a smaller plug to the left.Problem resolved. Truck doesn't like a mag mount antenna. Changed to a bolt-on 3/8-24 mount with a 5ft. Fire Stick attach to pick-up bed. SWR is less then 2 and radio transmits great using the 12v outlet. Phase two will be running the power harness through the firewall straight to the battery.
Anyone have suggestions where to gain access on firewall?
Hey Raine, first thank you for all the great info you provide. Just a FYI - He has a 2023 and there is a computer there now on the drivers side corner. Not sure if the pass-through is still there as that was for trucks with manual 6 speed and now has new sheetmetal.Easiest/most practical way is through the firewall on the left side of the truck. Next to the master cylinder, you'll see the main harness pass-through plus a smaller plug to the left.
1. HAH! I totally didn't notice the "2023" part in the thread title LOLHey Raine, first thank you for all the great info you provide. Just a FYI - He has a 2023 and there is a computer there now on the drivers side corner. Not sure if the pass-through is still there as that was for trucks with manual 6 speed and now has new sheetmetal.
I used that hole to run a GMRS radio antenna on my 2019. I had a 2020 for about 9 months and didn't have it long enough to see what is under that computer.
Cheers!
