Thank you for your reply, it is exactly where you said it would be. Thank you!IIRC it is just above the OBD connector taped tight to a harness.
what sub harness are you using, from the brake controller connection plug to the brake controllerThank you for your reply, it is exactly where you said it would be. Thank you!
Tekonsha 3050-P Brake Control Wiring Adapter for Nissanwhat sub harness are you using, from the brake controller connection plug to the brake controller
have you installed this ? went to etrailer.com, they list it for 2nd gen frontier. nothing yet for 2022
I’m hoping the plug is the same, it looks like the same style but if need be I may have to design my own plug. Ill let you know.have you installed this ? went to etrailer.com, they list it for 2nd gen frontier. nothing yet for 2022
I just hooked up the controller with that plug and it works perfectlyhave you installed this ? went to etrailer.com, they list it for 2nd gen frontier. nothing yet for 2022
No change. Nissan has kept the same plug on everything that can take a factory 7-pin going back 15+ years.have you installed this ? went to etrailer.com, they list it for 2nd gen frontier. nothing yet for 2022
