Hello Everyone,
After doing the differential fluid service, a few members recommended I move onto the t-case. Glad I did but more of that to come later.
Info:
Nissan recommends an inspection every 24,000 miles of the transfer case fluid and differential fluid. I bought my truck used with 32k miles so I didn't maintain it myself from new. Ive changed all other fluids besides the transmission due to the involved service but will be doing it at 40-45k miles.
Supplies / Items Needed:
2 quarts of Nissan D3M Transmission Fluid ($20.xx total $10/per at my local dealer. No fully supported equivalent exists as of today that I could find)
18mm Shallow Socket
Fluid transfer Pump
Procedure:
Note: From the factory, the fluid level was quite low. Nissan rates the T-Case to contain 1.5L of fluid and I don't believe any more than 750ml came out of the tcase. No leaks were apparent anywhere at the input / output shaft seals nor was there any indication of fluid leaking under the truck. If you have a 2020+, I would consider checking or just doing your T-Case fluid the next chance you get.
- I screwed the transfer pump into the Nissan D3M fluid and filled it up via the fill port. This took one bottle (946ml+ 550ish ml from the second bottle) to get the 1500ml of fluid that Nissan states in their materials.
The truck is now fully caught up on its fluids. All in all it was very easy and absolutely something any home mechanic could do versus paying dealer cost. I don't know if its just the gen2 with the new drivetrain or leading into the gen3 but the truck has been low on every fluid Ive replaced significantly except for oil. I again would review if you own a low mileage late gen2 and haven't reached these service intervals yet.
Info:
18mm Shallow Socket
Fluid transfer Pump
Procedure:
- I drove the vehicle up on ramps so I could easily scurry under from the driver side door to reach the T Case.
- First I loosened the fill plug on the transfer case. It is a 18mm on my 2020 Frontier with the newer VQ38DD drivetrain. I would assume this would be the same for gen3 as well. It came out fine with no noticeable metal shavings.
- I positioned the drain pan under the drain plug, unscrewed the plug, noticed no shavings, and let the old fluid drain out. I noted it was darker than new Nissan D3M fluid. Think like dark cranberry juice versus bright cherry syrup of some kind.
