I'm going to work on this over time but I have successfully used the Axxess/Metra adapters to put an aftermarket stereo in my 2019 Frontier retaining the backup camera and steering wheel controls. I understand there is another the 20 pin stereo connector that retains the steering wheel controls without having to re-pin the connector or program the buttons but I already owned the ASWC-1 from my old car. Also, since I purchased most of my gear from Crutchfield their tech support knows the Axxess/Metra products.
Parts Used:
Axxess/Metra 70-7552 https://www.amazon.com/gp/product/B000VXED54/
Metra 70-7552 Receiver Wiring Harness Connect a new car stereo in select 2007-up Infiniti, Nissan, Subaru, and Suzuki vehicles at Crutchfield
Axxess/Metra AX-NIS40SWC-6V Amazon.com: Axxess AX-NIS40SWC-6V Nissan Maxima w/o amp 2016-up Pre-Wired ASWC-1 Harness
Axxess AX-NIS40SWC-6V Steering Wheel Control Harness Install the Axxess ASWC-1 steering wheel control adapter in select 2016-up Nissan Maxima vehicles without splicing at Crutchfield
Axxess/Metra ASWC-1 https://www.amazon.com/Axxess-ASWC-1-Universal-Steering-Interface/dp/B00B4PJC9K
Axxess ASWC-1 Steering Wheel Control Adapter Connects your car's steering wheel audio controls to select aftermarket car stereos at Crutchfield
Metra 97-7619 Metra 95-7619 Dash Kit Fits select 2013-up Nissan models — double-DIN radios at Crutchfield
Electop USB A to B https://www.amazon.com/gp/product/B015PGGUWA/
Fender Washers
Tools Used:
Trim/Panel Remover https://www.amazon.com/gp/product/B07R44VJHN/
Philips Screw Driver
T10 Torx Driver
T20 Torx Driver
Crimping Tool Wire Stripper 2 Sewing Straight Pins
Almost all of these tools on the list are self explanatory except for the straight pins. Those are use to release the wires from the 40 pin plug. Any thin, flat, narrow object that will fit in the slot will work. The straight pins worked really well and by time I finished I was able to easily pull the pins out of one plug and put them in the new one easily.
I did use butt splices for the connections, while testing everything, but will soldier and heat shrink the connections at a later time.
Documentation Used:
95-7619 Installation Instructions http://www.metraonline.com/files/products/INST95-7619_web.pdf
ASWC-1 Vehicle Specific Instructions https://metradealer.com/files/aswc/ASWC-1_INST_862.pdf
ASWC-1 Programming Manual https://metra-static.s3.amazonaws.com/documents/ASWC-1_Manual_Programming.pdf
AX-NIS40SWC-6V https://metra-static.s3.amazonaws.com/documents/INSTAX-NIS40SWC-6V_web.pdf
To be continued......
Parts Used:
Fender Washers
Tools Used:
T10 Torx Driver
T20 Torx Driver
Documentation Used:
