I tapped my rear bumper turning in a tight spot and my missus is not happy. I need to do something about it, I don’t like the factory bumper plus the back side is rock chipped so a custom fabrication seems the way to go. Lucky for me my neighbor works in a fab shop.
I'm not the best at Google Sketch up so I can't draw a curved pipe. I want to curve the lower tube to match the angle of the 4" square tube and curve the lower step bars to match. I'm hoping the 4" x 3/16 HSS tubing will allow me to put my back up sensors and plate lamps back in as well as add some 3" LED backups inside the square tube.
I'm undecided whether I should drill holes for shackles in the 4 pie shaped verticals or weld a hanging D ring to the underside of the square tube. Also should I drill drain holes in the square tube or use glands for the wires to keep it sealed.
Any thoughts or suggestions are appreciated
