Well, that was cool - it took my half completed abandoned post from yesterday and added to my post today. Thus, covering the same ground twice. Ooops, now if we could do that with our trucks, maybe we could double our mpg?
same! after driving 70-75mph for years and now doing it at 65mph at around 2k rpm's..... i went from 15-16mpg to 20-21.8mpg..... and with a 2.5 hour trip to tahoe.... i only get there 10-15mins faster.... which isn't really worth it..... just my .02Looks like the OP has had enough of this banter and has checked out. It's just us chickens left to cluck about MPGs.
I never get good MPG in the winter. Been averaging less than 16mpg per tank. No long commute, winter blend, cold start...
MY on-board MPG computer is pretty accurate. Typically within 0.1 of hand calculations. This last tank I bought gas up on the summit, and by the time I got home 2K' lower I was at 22.5MPG. After yesterdays driving around town I am at 19.
It really sucked when I was down in WV and the speed limit was 75. Semi trucks were running 80-85… cars and motorcycles 85 and up. We set the cruise at 80 and we were the slowest thing on the road. Literally watching the fuel gauge drop. 🤬same! after driving 70-75mph for years and now doing it at 65mph at around 2k rpm's..... i went from 15-16mpg to 20-21.8mpg..... and with a 2.5 hour trip to tahoe.... i only get there 10-15mins faster.... which isn't really worth it..... just my .02
Member @rlholland somewhat regularly drives across west Texas where the speed limit is 80 on parts of I-10 and I-20. I have to make that trip eventually. I hope I don't get nerfed for going 70!It really sucked when I was down in WV and the speed limit was 75. Semi trucks were running 80-85… cars and motorcycles 85 and up. We set the cruise at 80 and we were the slowest thing on the road. Literally watching the fuel gauge drop. 🤬
dislike ya doing 80 in our trucks..... you can feel that it doesn't like itIt really sucked when I was down in WV and the speed limit was 75. Semi trucks were running 80-85… cars and motorcycles 85 and up. We set the cruise at 80 and we were the slowest thing on the road. Literally watching the fuel gauge drop. 🤬
I sometimes get a weird vibration doing 80mph or faster. I thought it was something with the driveline but neither me nor two dealerships found anything wrong. I chalk it up to buffeting of the camper shell/topper at those speeds.dislike ya doing 80 in our trucks..... you can feel that it doesn't like it
Are letting your truck idle longer so it warms up before you drive? That wastes fuel.I don't always go to the same gas station but I always get REGULAR.
I live in NJ also and notice a drastic decrease in mileage during winter months. From 18 mpg around town to around 15 mpg . I was told by a mechanic friend of mine it's because of the higher ethanol blend used for winter . Once it warms up you should see your mileage go back to normal.Bought an off-lease 2017 Frontier SV with about 23K miles on it. Window sticker showed 19/23 gas mileage. I figured that was high but 16/20 would have been acceptable. I travel 45 miles each way, 90% highway, Monday - Friday. I am lucky if I get 13MPG highway. And what's ironic, is the mileage is MUCH better when I am moving around the city. It jumps up to about 16MPG.
Because of this I have to fill up every other morning. I am unfortunately regretting this purchase. I never expected mileage to be this bad. And just for the record I have
1. Good tires, filled to recommended PSI
2. Air tight cover on tailgate to reduce drag
3. I am NOT locked on 4WD
4. I do NOT have a lead foot
5. Air filter is good
One more thing. This thing has a 21 Gallon tank? I notice once the light comes on, even if I drive it until the line is basically lined up with the E and I fill it up I never fill up more than 16 gallons. So even with the line on EMPTY this thing still has 5 gallons of reserve??
Any suggestions or tips?
Thanks in Advance.
I own a 2006 Frontier NISMO, 4.0 V6, and get about 18 mpg on the highway. Disappointed with the mileage, but I knew that going in. It’s an off road truck (not 4x4), just replaced all the cats, primary and secondary, o2 sensors, air filter etc. that’s about as good as it’s going to get.Bought an off-lease 2017 Frontier SV with about 23K miles on it. Window sticker showed 19/23 gas mileage. I figured that was high but 16/20 would have been acceptable. I travel 45 miles each way, 90% highway, Monday - Friday. I am lucky if I get 13MPG highway. And what's ironic, is the mileage is MUCH better when I am moving around the city. It jumps up to about 16MPG.
Thanks in Advance.
Is it an automatic transmission? I have a 6 speed and find if I keep the engine rpms under 2000, I can get 18 in the city and approach 25 highway. The engine really starts waking up at or above 3000 rpms. Also I use regular (87 octane) gas always. The milage stays above 20 even pulling a camper (and I do have a cap installed). To re-iterate - keep the rpms down... It can be quite a challenge because the engine sounds great...Bought an off-lease 2017 Frontier SV with about 23K miles on it. Window sticker showed 19/23 gas mileage. I figured that was high but 16/20 would have been acceptable. I travel 45 miles each way, 90% highway, Monday - Friday. I am lucky if I get 13MPG highway. And what's ironic, is the mileage is MUCH better when I am moving around the city. It jumps up to about 16MPG.
Thanks in Advance.
As P.S. a wise man once told me the sole of the shoe on the right foot is the greatest fuel economy device ever invented, if you’re on level road the cruise control is great but if there is any kind of hills or traffic where it’s on and off they’ll kill mpg.I bought a 2018 4.0L 2WD a month ago, first few tanks were 15.3, 15.4. I bought a device advertised on FB that plugs into the OBD II port. The last 2 tanks were 16.2 and 16.4 this is all in town driving. The power has increased and so far the mpg has increased, I bought it primarily for the increase in power as we are going to buy a small travel trailer and pull that. I was wondering if it was going to be snake oil but so far it seems to be helping. I knew when I bought the truck it wasn’t going to get good mpg because of the 5 spd automatic. The new 2020 model with the 9 speed gets better because the transmission can keep the engine closer to its power band, the closer you can keep the RPM in the torque curve the better mpg and performance. I guess if a person was to get lucky and had the skill to install a 9 spd out of a wrecked 2020 and change all the computers over to accept all the stuff that runs the transmission, but then again why not just go buy a new truck or learn to accept what you got.
To go along with what you said. An interesting read on the most fuel efficient gas engine ever conceived!As P.S. a wise man once told me the sole of the shoe on the right foot is the greatest fuel economy device ever invented, if you’re on level road the cruise control is great but if there is any kind of hills or traffic where it’s on and off they’ll kill mpg.
