1 - 20 of 23 Posts
Hello all,
I’m getting ready to change rotors and brakes. My question is where do I find a schematic of torque settings for caliper pin bolt and I believe it’s called the caliper housing? Also lug nut torque
There on the schematic for the brake caliper in the service manual. You need to find a copy of the FSM - used to be able to get them from Nico club but they were forced to take them down. Maybe someone here knows where to locate a copy.
www.nicoclub.com, they are back up on that site and you’ll find the manuals there. Look at the general section to understand which ones are ft lbs and which are inch lbs, the icons are white wrench and black wrench. You surely don’t want to stretch or snap a fastener.
Discussion Starter #5
I foun
It’s 100 ft lbs, the last value is ft pounds.
Be careful or you’ll have a problem.
That was fuzzy, look at the general information pages explanation of the manual.
The picture I supplied was for how to use the manual. The picture there they use as an example, I’ll get you the control arm picture.
Isn’t it showing mounting bracket 136 and sliding pin bolt 20?
Forgive me, I have you mixed up with someone doing the camber bolts, yes the last number is ft lbs. Those settings appear high and are the same when I just did the brakes and rotors in my Sentra, seemed like an awful lot.
Discussion Starter #14
Thanks Clint, so I’m not seeing things, you do see 136 and that seems high to me but that was the sentry number that you used?
It is but I wasn’t feeling it as I was turning the wrench which I do in increments so I set it at 110, I used to always just do it by ratchet and no torque wrench, and all was always fine after. The lug nuts on the wheels are usually 100-105 not sure why they spec so high.
I can’t tell you what to do but can say what I did.
Reactions: Peyton976
Yes. Those numbers are correct.
Those brackets go on very tight, on all makes of vehicles.
Be certain the bolts are in perfect shape, or replace them.
Use a premium quality socket. You don't want to have a problem now or next time trying to remove it.
I like to put a small dab of anti seize on the caliper mounting bracket bolts.
I agree but that actually messes with the torque setting as it reduces the friction when tightening down on the bolt.
1 - 20 of 23 Posts
