Make sure you have a good breaker bar, the lower bolt on the shocks is a bear to get loose. My truck is only 4 years old and I actually broke my breaker bar doing this exact job.
BTW, if you are like me you will look at it and wonder if you can get away with out pulling the shock completely off. Well you cant, the upper block requires you to turn the shock 180 degrees to re mount to the top.
