Silly Question i was doing my rear brakes yesterday i bought a new Caliper Guide Pin Set the New Set came with 2 Pins with rubber inserts that go onto ends. as i took the old ones off i noticed the top one doesn't have the rubber insert on it as the bottom one does have the rubber insert at end off it. My question is does it matter that the new ones i installed both have the rubber inserts at the end off it top and bottom or is there a reason on the factory guide pins that the top one was all metal and the bottom has the rubber insert at end off pin?? cause i installed the new ones with both having the rubber inserts at end of the pins any feedback would be great
