Hello guys I have a issue I got 13 Frontier CC 4.0 my heating ain't working right I got digital readout only getting heat set at 90 anything lower nothing at idle or nothing at driving and sometimes get heat at 80 on vent and when switch to front defrost goes cool and vise Versa tried getting air out of system but don't know if I waited long enough some bubbles came out don't know if I should of waited longer any info would be great
· Super Moderator
I bought this tool and works great getting the air out of the system. On my last Frontier there was Luke warm air at idle but hot driving and this fixed it. Hopefully it corrects your issue as well.
Lisle 24610 Spill-Free Funnel, was on amazon.
· Super Moderator
I put he truck facing uphill on small incline (my driveway) then installed the funnel and filled it halfway and watched the bubbles come and the coolant go into the radiator. You can also raise the idle and make it happen sooner. When done you install the plug and remove the funnel without spilling coolant. Make sure the heat is on while doing the procedure.
