Hello,
I just noticed my 2012 Frontier 6 speed, has a good amount of what appears oil seepage around the seal of the rear differential cover. My truck has about 80k miles on it, and I purchased it with 50k, so it's probably due for a diff oil change anyway. After reading on this forum a little bit, it appears the breather vent is easily prone to getting clogged/stuck, allowing the diff not to vent properly. I have already ordered the parts in order to do the vent mod with the toyota union and the fuel filter mounted higher up. I would like to reseal the rear diff cover to ensure I have a good seal. Now, from what I understand my truck is manual, so I have the m266 differential. I plan on draining and refilling the diff with 75w-140, but while I'm at it would like to remove the cover and put a new gasket on it. I'm going to reuse the stock rear diff cover. I found the Mag-Hytec gasket that is made for Titans, but it seems like certain frontiers and xterras have been using them too. I was ready to order one, but the price was 28 plus another 13 for shipping which seems a little high. I really have no need to have a reusable gasket as I don't off road or do any mods. I'm just wondering whats the alternative to the gasket? I guess the red rtv and you make a bead around the cover? I would like to complete this all in the next 2 weeks since I'll have some time off, and my truck is due for an oil change and tire rotation. I like the idea of a gasket, but I'm somewhat tight on money and almost $45 seems a bit much for a gasket. If anyone knows of a cheaper alternative or a better place to order I would appreciate it.
Btw I attached a photo for reference. I need to get my truck washed with the undercarriage cleaned before I start this. They salt like crazy in the Garden State.
Any feedback or info would be greatly appreciated. I was planning on using Valvoline Synpower 75w-140 as it's the cheapest and I can get it locally. Again I don't do any towing with my truck, just occasionally haul outdoor power equipment in the bed. Thanks!
