Thanks for the advise. I wonder what Nissan will do to it.
What 6" lift kit did they use? I am not sure they are going to warranty the work at all. They may play the "warranty void" card and play dumb.
If they do anything, I would imagine they are going to just replace the Dshaft and call it a day. They will hope that you are out of warranty the next time it happens and then want to charge you.
Thinking about it, I am going to laugh a bit if they used a simple block lift. This will cause extreme axle wrap on our Frontier's.
I imagine moving the brackets would be the better of the two methods.
Moving the brackets will work but if you change out the lift in the future or do anything, it will have to be changed again. I would stick with the shim or tappered lift blocks if you have to use blocks and leave it like that for a bit.
