1 - 4 of 4 Posts
All,
My 07 manual is intermittently not starting. It's definitely not the battery. I push the clutch in and turn the key - I can hear the relay under the passenger dash click but no start, no crank, nada - it's as if the clutch isn't pushed in. If I try to start without the clutch pushed in it acts exactly the same.
Before I order a new inhibitor switch, is there anything I can test? Maybe bypass the switch?
Thanks
Lou
Discussion Starter · #2 · (Edited)
All,
Thanks
Lou
Never mind, stupid plastic thingy on clutch pedal is broken and no longer making good contact with the switch. I took it out and replaced it with a few neoprene spacers I had floating around. Good to go. Thanks!
good job. i actually hated the switch so i bypassed it and wired in a kill switch
but i left the OE in place so upon casual viewing it would look intact. if, after
40 years of driving a manual trans, I've not learned to step on the clutch prior
to starting the ignition, i deserve the jerk. :)
mine had the same issue. I was able to talk to the guy at the body shop i used to work at and he gave me a bunch of the push rivets so i could find one that fit.
1 - 4 of 4 Posts
