1 - 2 of 2 Posts
Before I start taking things apart I need a little input. I have the relay package from Nissan mounted in the front cab wall cavity.
Until now the trailer lights Have worked perfectly. Recently the turn and stoplights have worked but no more. The running lights are still ok. The trailer lights are Ok,tested with another Frontier. Is there a fuse somewhere that could have blown?
Any help would be appreciated.:frown:
Don't know if you ever solved this problem but there is an add on harness to correct a possible problem with the trailer lights overloading the circuitry and frying the BCM (body control module). Your truck may have this updated harness. Look up under the dash and find a bundle of wires that are taped together with a couple of fuse holders attached to it. My guess is one of the fuses is blown.
Here is a link to a picture of what the harness looks like.
http://www.clubfrontier.org/forums/f8/mystery-harness-255505/
1 - 2 of 2 Posts
