1 - 2 of 2 Posts
Just wanted to post some photos of the replacement I did. I was looking for some images that had all the details on a 2WD Hub replacement but all of them showed for the most part the 4WD model.
I was able to find a nice guide that has a lot of repair data on it with blow up drawings. https://carmanuals2.com/get/nissan-frontier-2006-front-axle-section-fax-47186
For the most part it took me about 3 hours to do both sides
The PDF has the diagrams and photos of the replacement.
The parts cost me only $140. on line! So a saved a bunch not having it done at a shop!
To install this part on a 2006 Nissan Frontier you will need a 17mm socket, a 19 mm socket, a 21 mm socket (for lug nuts so this could be a tire iron or whatever), a large ratchet, a torque wrench that can go up to 100 lbs, a 2lb sledge hammer, a large rubber mallet, large flat head screwdriver for prying, and of course a jack and jack stands. No bearing puller is needed for the front wheel bearings of this vehicle as the bearing does not go over a spindle.
Good Luck!
Rogue Admin
2007 LE 4x4 Crew Cab Long Box
I've never liked doing hubs or ball joints - I leave it to a shop. though, BFH moments can be rewarding. ::grin::
Thanks for sharing.
1 - 2 of 2 Posts
