I just bought a 4.0l and the rpm is very high and seems to rev up when changing gears,
On idle it’s 1200 rpm
It drops when I take off with clutch in,
What could it be ?
One thing is when I rev it stays at around 3000 rpm then there is a tssssss sound from the engine bay and it drops to 1200 sorry for sounding dumb but there’s no other way of explaining it
You may want to try the idle re-learn procedure to see if it fixes it, or it could have a large vacuum leak, but I would think if it was, it would throw a code.
I second that I forgot to hook up the breather that connects to the air intake and got a code a day later. Try to do an air idle relearn and I would think that would fix it.
