Username: The Other Mike1357
Year: 2004
Make: Nissan
Model: Frontier
Trim: XE
Color: Black
Engine:
-8.8:1 CP Pistons
-Brian Crower Stage 2 Turbo Cams
-Crower Dual Valve Springs
-Crower Titanium Retainers
-Carillo Connecting Rods
-Ferrea Stainless Steel Valves
-Z1 Motorsports Bronze Valve Guides
-Supertech Viton Valve Seals
-Cometic Head Gasket
-King Main & Connecting Rod Bearings
-ARP Head Studs
-Xcessive Intake Manifold
-Xcessive Top Feed Fuel Rail
-Injector Dynamics 850CC Top Feed Fuel Injectors
-Aeromotive A1000 Fuel Pressure Regulator
-CXRacing 11 Gauge Exhaust Manifold
-Turbosmart Ultragate 38 External Wastegate
-Boost Lab 5757 Journal Bearing Turbo
-HKS Blow Off Valve
-3" Turbo Back Exhaust
-L28 Turbo Oil Pump
Engine Electronics:
-S13 240SX ECM
-Walbro 255lph Fuel Pump
-HKS EVC EZ II Boost Controller
-GReddy Turbo Timer
-Defi Boost Gauge
-Prosport Oil Pressure Gauge
-NGK Powerdex AFX Wideband AFR
Interior:
-Mogg Weighted Shift Knob
-Gloss Black Dash
Exterior:
Drivetrain:
-350Z Clutch and Pressure Plate
-Caterpillar Carrier Bearing
Suspension & Tires:
-Level8 6 Spoke Wheels
-XTerra Torsion Bars
-Quad Cab Rear Sway Bar
-Drilled and Slotted Front Brake Rotors
In Progress:
- Getting the thing running again.
Year: 2004
Make: Nissan
Model: Frontier
Trim: XE
Color: Black
Engine:
-8.8:1 CP Pistons
-ARP Head Studs
-HKS Blow Off Valve
-L28 Turbo Oil Pump
Engine Electronics:
-S13 240SX ECM
-GReddy Turbo Timer
-Defi Boost Gauge
Interior:
-Gloss Black Dash
Exterior:
Drivetrain:
Suspension & Tires:
In Progress:
