1 - 8 of 8 Posts
i Have a 2000 XE 2.4L and I'm getting a Mystery Coolant Leak Center of engine.
It only leaks sometimes, not all the time after a long drive there is puddle under the center of the engine oil pan.
Nothing near the front under of the pump, thermostat, radiator or hoses.
I'm thinking it may be the intake manifold or a coolant hose? I know the intake has small coolant lines in them.
I have attached images of a 2.4L Intake as reference.
Thank you for your time. ::smile::
I had a similar situation this week on my 2000 Frontier 4 cylinder. The leak was near and under the front of the intake manifold. Let me say what helped a lot was ordering a MIGHTY VAC COOLANT PRESSURE TESTER from Amazon for like 36 bucks !!! It turns out there are 4 coolant hoses under the intake manifold. The most common one to leak is a U-shaped hose that Auto Zone calls a "bypass hose". Visibility and access are achieved by unbolting the power steering pump (and laying it back without disconnecting the hoses), the cast iron pump bracket to the head, the battery, and the upper hose. There is another straighter or "dog-leg" hose that is helpful to remove (and replace) at the same time). With those removed, there is JUST enough room to access that U-shaped hose without removing the intake manifold). The Auto Zone part number for the Dayco hose (which they stock) is B88354. The beauty of having the pressure tester is that you can simulate hot driving pressures without heating up the engine AND you can quality check that the leak was fixed BEFORE finishing all the reassembly. You can also borrow pressure testers from Autozone and Oreilly, but the deposit is pretty hefty (of course, you get it back if returned in 48 hours). Hope this helps someone !!!!
Thank I have the same problem and wondering where it was coming from? Also it only does this during the cold seasons. Thank you for the info.
I've finally have tackle the leak and it was the u shape hose. Dry rotted by the spring clamp. Like you have stated above i did take the alternator, steering pump & bracket,and both main water hoses. And yes it still was tight and working it in a awkward positions at times but after few adult beverages and conversation to myself,its completed! Thank you again.
Good. You fixed it BEFORE it caused engine damage. That's the way to do stuff, and why we should all be observant with our vehicles.
That bypass coolant hose and the vacuum hose under the EGR transducer are very common issues.
I also had the vacuum hose under the EGR transducer go bad on my '98, had service engine code. It was a rubber hose under 3" in length, was totally corroded and broken clean through in the middle. Took me like 45 minutes to find that, after checking the EGR itself with a hand vacuum pump.
1 - 8 of 8 Posts
