2022 Frontier S King Cab 4x4
I am considering doing a 2" leveling kit, adding wheel spacers, and a little bit bigger tire to my truck. I don't have a 4x4, so I don't want to fake the funk, but I would like to give it a little tougher look. I was reading a recent thread hunterdan posted about his daystar kit, and I have a few questions of my own from reading his post and replies:
1. One of the questions asked was if he noticed any wheel rub. I thought a lift was supposed to help this situation, not hinder it. Am I wrong in that thinking? He is still running stock tires, so I would have imagined tire clearance would have improved, not the other way around. One of the reasons I would want to do a 2" leveling kit was to run a slightly bigger tire. I've read that a 265/75/16 was the tire size to run without more of a lift.
2. Do wheel spacers cause the axle to sag? I remember all the idiots back in the day with wide rims on their cars making the axle sag eventually. Now I'm only talking a 1" or 1.5" spacer from wheel adapter dot com, but if there is any risk of that happening then I'll skip it. I'm sure I would have read that on here if it did happen, but I just wanted to make sure.
Hey!
I recently did a leveling kit like the one you're talking about. I did a little research, and there is actually a kit available on ebay through a store called "Auto Spring Kits" that is, in my opinion, a little better than the Daystar one. It comes with spacers for the front, and and an add-a-leaf for the back. I did that plus a 1" block for the back as well. It looks really good. Not too high. Just enough. Still running stock tires, but that will change soon.
There shouldn't be any tire rub. My stock size was 265/70/16 and now I'm running 265/75/16s. They are about an inch taller and look great with my set up now. Tire clearance is a bit better. The only minor issue I have is the coil bucket contact when the front tire drops off a curb or something like that. I am going to get little rubber bump stops to muffler the noise some. I was looking at the ebay kits as well. I was going to buy one, but when I saw this pop up for sale I couldn't pass it up. The ebay kits are a killer deal for what you get though. I will say that the 2" lift just in the front really changes the look of the truck. Looks much more aggressive now. Next up is going to be an AAL in the rear to bring it up some.
Dan
