ok first off i bought the 4x4 parts 2" body lift and i read the instructions and then threw them out because they are worthless . ok here what i did and made it a lot easier for me , so i hope it makes it easy for you . here is the picture of what was in the box , and i didn't use a lot of it so they are wasting there time putting in the box .
so first i pre lubed every bolt on the body and some of the other bolts on the rail by the driver front wheel well i had to disconnect the bracket holding on the brake lines , here is the picture of the lubed parts
these are just the body mounts. so i removed all of the body mount 6 on each side 3 for the bed and 3 for the body .
the directions said to remove the wire clipped on the rear bumper i did not need to and it also said remove the skrews on fire wall for the ac line here is the picture of what i did not disconnect
it also said to remove the lower shaft to rack and pinion. i did not , i only loosened the blot for the steering shaft thats it, heres the picture ,
like i said just the bolt in the picture that is all i loosened and the after the lift i re thightened it .
next i removed the bumper and installed the relocation brackets.
first remove the valance .
i threw this away i don't need it and if you are going to run bigger tire you'll need to trim this anyway .
remove this screw 1 on the left and right.
then remove the screws behind the bumper near the fog light wire one on each side . "disconnect the fog light wires on both sides"
then remove the grill , a few black tabs on the top and inside and it'll come off
then romve the last two bolts on the top of front bumper here the picture.
then remove the crash bumper here the picture .
remove bolts where the arrows are on pass. and drivers side. on back of the bumper remove some on the metal to make it fit . here the picture .
i did this on both sides . after you install the bumper relocation brackets mock it up and mark the spots to cut on both sides , and cut .
heres the picture for the bumper brackets installed .
