My plan was to pick up a wrecked titan for parts. I plan on t-swapping the front suspension for more travel. Radflos should address the rest of suspension issues. If I am t-swapped can I run titan spindles without any mods? I know the lug pattern is different. On the rear axle, worst case scenario is I get 3.69 gears, which is lower than the lowest stock titan gearset without compromising highway performance in a much lighter truck. The rear brakes on the 2.5 are the same as the v6, so they should be fine. My only main concern is the location of engine and trans mounts in the chassis.Best idea, get a wrecked Titan and take the entire drive line, computer and gauges. Not a cheap proposition.
