WELCOME to ClubFrontier....
1998-2004 Nissan Frontiers are typically refered to as "1st generation frontiers" or "1st gens"
These trucks have a torsion bar front suspension, and a leaf spring rear suspension....
Some of the most common questions are...
1) How to lift my truck
2) What lifts are available
3) What size tires can i run
4) What Axle's do i have
I hope to answer MOST of these basic questions in this thread. But feel free to start additional threads with deeper questions...
WEBSITES TO KNOW....
www.4x4parts.com
www.calmini.com
www.spencerlowracing.com
FRONT SUSPENSION
The 1st gen frontier has the ability to adjust ride height via "pre-loading" the torsion bars... or as its better known as.... adjusting or cranking them.... Basically the torsion bar is a spring... It is connected to the LCA (lower control arm) in the front of your truck, and connected to a crossmember and adjuster in the central area of your truck. If you look under the truck, you will see on each side, just inside of the frame rails, a long bar that extends back from the LCA.. thats your torsion bar...
ALL LIFTS with the exception of very high dollar SAS or Coil Over conversion lift your truck via a torsion bar crank... Some kits have the option of upgrading to aftermarket torsion bars, but this is NOT needed.. some prefer, some prefer stock bars... The stock torsion bars have more than enough ability to give you well over the maximum 3+" of lift.
LIFT OPTIONS...
0" to 2" - You can simply adjust your torsion bars...
2.5" to 3" - You can either purchase a complete lift kit, or purchase aftermarket UCA's
To adjust your torsion bars... You simply jack up the front end of your truck, secure it with the wheels slightly off the ground, to remove any tension on the front suspension, and tighten the adjuster bolts.. There are two 19mm nuts on the top of the adjuster bolt... the top being a lock nut... simply loosen the top nut, then tightned the adjuster bolt to adjust ride height... lower truck, measure... and repeat untill you have desired height.... REMEMBER.... you want a minimum of 1/2" of room between the bottom of your UCA, and the bump stop which is below it.....
or click here for some detailed instructions with pictures...
TorsionBarWriteUp
It is said to always get an alighnment after adjusting torsion bars, however in MOST cases, it will not effect your alignmnt, however this is YOUR CHOICE... if it needs the alignment, GET IT DONE.
You always have the option of purchasing a lift "kit" that is complete with all that is needed... However there are lots of people who do the lifts in steps... Lots of people start off with a simple torsion bar adjustment, then decide they want more.... Here are your options...
1) Add aftermarket UCA's. Basically as you adjust the height of your truck with your stock UCA's, the angle that they sit changes, which also changes the ball joint angle and slightly changes your camber. Aftermarket UCA's DO NOT ACTUALLY LIFT YOUR TRUCK... The torsion bars do... The aftermarket UCA's are simply designed at a differant angle, so that when the truck is adjusted by 2.5-3", the ball joint angles, and your camber are at the correct points... There are several options, and most of them are in the $350.00 range.
AS I UNDERSTAND IT... Now keep in mind, because we use torsion bars, there is the ability to adjust... but... the lift amounts below are what I've come to understand the aftermarket UCA's to be designed to provide...
AC (4x4parts) and Rancho - 2.5"... both of these are almost identical.
Calmini and SLR Econ's - 3"... both of these are almost the same exact design.
SLR Stage series - 3" plus added down travel....
STOCK TORSION BARS VS. AFTERMARKET
Aftermarket torsion bars are basically the same thing, except they have a higher spring rate... Basically they are stiffer... Some like this, as they feel them to be stronger, some don't because its said that the stock bars will flex better... This is 100% a matter of personal preferance...They are NOT needed to achieve the lfit..
RE-INDEX - In the even that you are adjusting your torsion bars, and the adjuster bolts run out of adjusting room.. (the brackets they go through have no more movement available)... you can reindex the stock bars... Basically the ends of the bars are splined... you simply remove the adjuster bolt, back the bars out of the ends... rotate them by 1 or 2 splines, which will give you the extra ability to adjust higher...
SHOCKS... With a simple torsion bar adjustment, its not requried to upgrade shocks, but lots of people do.... If you are lifting to the 2.5 to 3" range... you will need to upgrade...
Now... There are wide spread comments on the good/bad effects of adjusting your torsion bars.... As most of us have found... There really is no DOWN side to doing this....
Will your truck's ride get stiffer due to adjusting the torsion bars? NO!.. however people do tend to say it does... And the reason has little to do with the torsion bars, but more in the fact that they are adjusting to much. When you adjust your torsion bars for more lift, you are changing the angles that your control arms sit. Just under your UCA (upper control arm) there is a little black rubber bump stop. This is there so that when the front end goes up, and the wheels "droop" or drop down, it prevents the suspension from drooping to far, and causing your CV's (axles) to bind, and possibly brake. Normally when you go over a bump, your front suspension has plenty of room to travel before that bump stop, so it never actually contacts it. But by lifting more than 1.5-2" this way, you are causing the front end to contact those stops more than regular, resulting in what seems to be a stiff ride. Worn out shocks can also play a part in this, however the simple answer, is distance between UCA and bump stop... You can purchase "low profile" bump stops from
www.4x4parts.com which can help with some of this.
REAR SUSPENSION....
you have 3 basic options....
1) Blocks
2) Shackles
3) AAL's (add a leaf) or custom leaf packs.
I personally don't like blocks.. but they work... but i won't go into details on the
SHACKLES... You have several options... the aftermarket parts places listed do sell them... OR... AutoZone and several other places do sell universal ones that can be used for aprox $14.00... The aftermarket ones available are stronger, but the universal ones are usable... Shackles will provide the most flex of all these options...
AAL's.. they sell Add A Leafs that range from cheaper 1pc to more exspensive 3pc sets... This is the BEST way.. however they don't flex as good as shackles, so lots of people combine shackes and aal's..
BODY LIFTS...
4x4parts.com sells a 2" and a 3" body lift... The 2" is less work to install, however both work great.. A body lift ONLY raises the body of the truck... giving it the lifted look, however the suspension and frame are still at the EXACT same height.... The one MAJOR advangate with a body lift is the fact that it allows for bigger tires, because it raises the wheel well higher above the tire, which creates more room for larger tires... Body lifts are typically less money to purchase, but way more work to install...
TIRE SIZES....
FLAT OUT... there is NO answer for the biggest tire you can run...
With minimal change, a 31" tire is usually never a problem... With a body lift, or 2" or better suspesion lift, a 32" tire is IDEAL...
YES... you can make larger tires fit... NO... there is no way to tell you what you can fit...
The size tire you can fit all comes down to what rim your using... and what the backspacing is... the wider the stance, the smaller the tire, because as you move to a wider offset, at full turn, your tire is no longer tucked inside the fender, and will rub with a smaller tire than with stock rims... Larger tires are simply trial and error... Sorry, the simple answer just doesn't exist....
AXLES... What do I have??? This link should just about cover it.....
http://nissan4wheelers.com/eve/ubb.x/a/tpc/f/3766078435/m/88310151411
Thanks to all who have contributed to this thread. As other things get posted in this thread, I will update the original post with most of this information, and/or links to the information. We are attempting to stay as factual as possible with everything posted here, however based on the type of suspension we have, and differant offsets of rims people use, it is intirely possible for two people to have completely differant results in regards to several things covered in this thread...
