I'm the second owner (original owner purchased brand new and drove till it had 100K). Car was bone stock when I purchased it and had no rust(South Carolina car). Over the past nine years or so, I've slowly built the car into a fast/fun daily driver that has always been garage kept. Oil has always been changed every 3k miles with mobile 1 synthetic it's and always run with 93 octane. Car has 128K miles on it.
Timing belt/water pump was done at 120K. Turbo has less than 1k miles on it.
I may be partial, but this one of the cleanest 1G's that I've seen.
Engine
90 Oil filter housing/ with aftermarket oil cooler(AN fittings)
Cruise delete
Buschur Racing alternator relocation kit (where A/C compressor use to sit)
A/C delete
Transmission
Exedy stage 1 clutch
ACT streetlight flywheel
Sheptrans stage 1 transmission
Turbo
FP 20G
FP 4” intake
2G MAS
EVO III Exhaust manifold
122 performance O2 (Tial 38mm WG)
2.5” Down pipe into 3” catback (no cat) straight through mangaflow muffler
Intercooler
Spearco 2-210 FMIC (old IRC 2-210 kit)
Electronics
Autometer phantom (boost/oil pressure/water temp)
PLX wideband
AFC (blue screen)
Pocketlogger
Apexi turbo timer
Jumptronix A/F
Fuel
FIC 750cc injectors
Buschur racing fuel pressure regulator/SX
Walbro 255lph fuel pump
Suspension
KYB/AGX
Brakes
92-94 dual piston calipers(brembo rotors/HAWK pads Porterfield Carbon/Kevlar Brake Pads R4-S pads)
Ignition
NGK BPR7es spark plugs
NGK spark plug wires
Audio
Infinity Kappa 6.5/6X9
Sony 4X75watt amp
Sony head unit
10” bazooka tube
Misc
Strut tower braces (front and rear)
Battery relocated to trunk (150A stinger fuse)
SS brake lines (all four corners)
Coolant over flow moved to the firewall (bottle replaced but sensor is still operational)
Racing bumpers (front and rear)
Tires/Wheels
Rota subzeros
Toyo Proxes 4 (225/45/zr17)
Rear wiper and all associated hard ware deleted
Joe P MBC
RRE Breather
$6500 obo
Pics can be seen here:
Talon pictures by josywells - Photobucket
Engine
Cruise delete
A/C delete
Transmission
Turbo
FP 20G
FP 4” intake
2G MAS
Intercooler
Electronics
PLX wideband
AFC (blue screen)
Pocketlogger
Apexi turbo timer
Jumptronix A/F
Fuel
FIC 750cc injectors
Suspension
KYB/AGX
Brakes
Ignition
Audio
Sony 4X75watt amp
Sony head unit
10” bazooka tube
Misc
Tires/Wheels
Rota subzeros
Joe P MBC
RRE Breather
$6500 obo
