1 - 7 of 7 Posts
I know the subject has been discussed many times. I still can't find what I'm looking for though.
Using oem tires (265 70 18) (32.6")with thinnest adapter that would work (wheeladapter.com hub/wheel centric)
Will it rub, and if so, what would be the minimum lift to no rub(least expensive).
I assume you are talking about the 2nd gen Frontiers. Your skinniest adapters will probably be between 1 and 1.5in in thickness. That size tire is stock so there should be no rubbing.
Discussion Starter #3
Thanks for the response... I have an 07 SE 2wd.
the size is 265-70-18 which comes out to 32.6 according to tirerack. I thought the tallest tire that came stock to be the nismo/pro4x which is right at 32". It doesn't seem like i'm really adding too much more then stock, but I can't get a sense for how that 1.5" spacer complicates things.
you do realize titan 18s are 6 on 5.5 right?
1 - 7 of 7 Posts
