1 - 3 of 3 Posts
Ton of threads on this...
...the OEM rack is labelled '05-'14 because after that they stopped putting them on the Frontier (to gain better mpg ratings). The Frontier roof hasn't changed since '05 so you can put the OEM rack (or an aftermarket clone) on your '17. The one detail with the OEM install is that you need the 4 mounting plates that go under the roof, in between the roof and the headliner. Aftermarket clone racks come with rivnuts, and some come with the plates. Check this thread, the OP bought a clone rack that came with plates:
http://www.clubfrontier.org/forums/f10/roof-rack-build-312337/
EDIT: this one too:
http://www.clubfrontier.org/forums/f10/how-install-2nd-generation-roof-rack-56407/
1 - 3 of 3 Posts
