Finally finished up the last few things on this DIY project today. I would say its a very easy project - finding the materials may be the only hold-up to some.
Not wanting to pay $80 or more for a hi-lift mount (which is more than the jack) and having my jack bouncing around in box and denting it, I thought it best to find another way to mount the hi-lift. Having some UHMW laying around from my body lift, I figured it would make a great material for using against the utilitrack. Some crap metal, left over UHMW and $5 in bolts/nuts later...
So, I got some 1/4" plate, punched some holes into it, welded one bolt from the back and painted them up. I used 1" by 1" block tube about 2.5" long on top of the bolt - this will be what the jack sits against.
Then I bought some spring nuts to use inside of the Utilitrack. Here you will see I have the mounting bolts with a variety of nuts to use for hoilding the jack afterwards. I wasn't sure if I wanted to use double nuts, nylon nuts, or wing nuts....I eventually went with wing nuts. if they don't hold well, I will go to the nylon nuts
I used some Loctite inside the spring nuts, just to help hold them a little better
The spacing of 2" blocks, 1/4" plate, and 1" tube is the perfect distance to hold the jack away from the Utilitrack (I compared the measurements to eglaisi's Fabworks holders).
And here it is, installed. Took about 15 minutes. Don't forget I have a long box so it looks small in there.
